[phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 279: mysqli_fetch_assoc(): Couldn't fetch mysqli_result [phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 343: mysqli_free_result(): Couldn't fetch mysqli_result [phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 279: mysqli_fetch_assoc(): Couldn't fetch mysqli_result [phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 343: mysqli_free_result(): Couldn't fetch mysqli_result [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4191: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3076) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4191: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3076) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4191: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3076) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4191: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3076) [phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 279: mysqli_fetch_assoc(): Couldn't fetch mysqli_result [phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 343: mysqli_free_result(): Couldn't fetch mysqli_result Расшивка амфенола. - Страница 3 - Форум мини АТС компании Солярис
shkiper516 писал(а): ↑21 авг 2025, 15:54
Тяжелый случай.
А на амфеноле порт-то какой?
в том же и вопрос:
т.е. 22-47 - аналоговая,
23-47- цифровая получается для 8го порта (108 внутреннего номера)?
И что не может быть, 8 портовая карта, 8 номеров на ней?
vda писал(а): ↑25 авг 2025, 06:54
DT343 - цифровой системник. Ему достаточной одной пары
Вместо обычного аппарата на средние контакты RJ11 подключал - не светится экран и нет зуммера.
Где бы посмотреть схему как подключить? может питание надо?, но для бп нет разъема..
