Проблема сетевого вызова по SIP протоколу
Sinhro
Сообщение Sinhro »
Проблема в работе SIP протокола.
Настроен SIP транк (без регистрации) между LG eMG800 и W&T-NS100.
Периодически не работает входящий сетевой вызов от LG eMG800 на W&T-NS100.
При этом в этот момент исходящий вызов от W&T-NS100 работает.
Статус линий СО и абонентов LG eMG800 в этот момент свободен.
По истечении определенного времени входящие на W&T-NS100 снова работают.
W&T-NS100 отклоняет входящий вызов.
Прилагаю описание файла damp:
No. Time Source Destination Protocol Length Info
1 0.000000 192.168.46.20 192.168.40.245 SIP 597 Status: 403 Forbidden |
Frame 1: 597 bytes on wire (4776 bits), 597 bytes captured (4776 bits)
Encapsulation type: Ethernet (1)
Arrival Time: Nov 26, 2025 12:45:22.272896000 RTZ 2 (зима)
UTC Arrival Time: Nov 26, 2025 09:45:22.272896000 UTC
Epoch Arrival Time: 1764150322.272896000
[Time shift for this packet: 0.000000000 seconds]
[Time delta from previous captured frame: 0.000000000 seconds]
[Time delta from previous displayed frame: 0.000000000 seconds]
[Time since reference or first frame: 0.000000000 seconds]
Frame Number: 1
Frame Length: 597 bytes (4776 bits)
Capture Length: 597 bytes (4776 bits)
[Frame is marked: False]
[Frame is ignored: False]
[Protocols in frame: eth:ethertype:ip:udp:sip]
[Coloring Rule Name: UDP]
[Coloring Rule String: udp]
Ethernet II, Src: 52:54:00:05:dc:a0 (52:54:00:05:dc:a0), Dst: EricssonLGEn_16:95:3d (b0:61:c7:16:95:3d)
Destination: EricssonLGEn_16:95:3d (b0:61:c7:16:95:3d)
Address: EricssonLGEn_16:95:3d (b0:61:c7:16:95:3d)
.... ..0. .... .... .... .... = LG bit: Globally unique address (factory default)
.... ...0 .... .... .... .... = IG bit: Individual address (unicast)
Source: 52:54:00:05:dc:a0 (52:54:00:05:dc:a0)
Address: 52:54:00:05:dc:a0 (52:54:00:05:dc:a0)
.... ..1. .... .... .... .... = LG bit: Locally administered address (this is NOT the factory default)
Type: IPv4 (0x0800)
Internet Protocol Version 4, Src: 192.168.46.20, Dst: 192.168.40.245
0100 .... = Version: 4
.... 0101 = Header Length: 20 bytes (5)
Differentiated Services Field: 0xfc (DSCP: Unknown, ECN: Not-ECT)
1111 11.. = Differentiated Services Codepoint: Unknown (63)
.... ..00 = Explicit Congestion Notification: Not ECN-Capable Transport (0)
Total Length: 583
Identification: 0x46b9 (18105)
000. .... = Flags: 0x0
0... .... = Reserved bit: Not set
.0.. .... = Don't fragment: Not set
..0. .... = More fragments: Not set
...0 0000 0000 0000 = Fragment Offset: 0
Time to Live: 62
Protocol: UDP (17)
Header Checksum: 0x6c9d [validation disabled]
[Header checksum status: Unverified]
Source Address: 192.168.46.20
Destination Address: 192.168.40.245
User Datagram Protocol, Src Port: 30565, Dst Port: 5060
Source Port: 30565
Destination Port: 5060
Length: 563
Checksum: 0xc8b6 [unverified]
[Checksum Status: Unverified]
[Stream index: 0]
[Timestamps]
[Time since first frame: 0.000000000 seconds]
[Time since previous frame: 0.000000000 seconds]
UDP payload (555 bytes)
Session Initiation Protocol (403)
Status-Line: SIP/2.0 403 Forbidden
Status-Code: 403
[Resent Packet: False]
Message Header
Via: SIP/2.0/UDP 192.168.40.245:5060;branch=z9hG4bK-306d93-bd2c0832-157a1520-616ec938;received=192.168.40.245;rport=6093
Transport: UDP
Sent-by Address: 192.168.40.245
Sent-by port: 5060
Branch: z9hG4bK-306d93-bd2c0832-157a1520-616ec938
Received: 192.168.40.245
RPort: 6093
From: <sip:190@192.168.46.20:5060>;tag=6171a3b8-f91fa8c0-13dd-65014-306d93-4477e93-306d93
SIP from address: sip:190@192.168.46.20:5060
SIP from address User Part: 190
SIP from address Host Part: 192.168.46.20
SIP from address Host Port: 5060
SIP from tag: 6171a3b8-f91fa8c0-13dd-65014-306d93-4477e93-306d93
To: <sip:600@192.168.46.20:30565>;tag=as7b51249f
SIP to address: sip:600@192.168.46.20:30565
SIP to address User Part: 600
SIP to address Host Part: 192.168.46.20
SIP to address Host Port: 30565
SIP to tag: as7b51249f
Call-ID: 618f8e10-f91fa8c0-13dd-65014-306d93-4632449d-306d93
[Generated Call-ID: 618f8e10-f91fa8c0-13dd-65014-306d93-4632449d-306d93]
CSeq: 1 INVITE
Sequence Number: 1
Method: INVITE
Server: W&T
Allow: INVITE, ACK, CANCEL, OPTIONS, PRACK, UPDATE, BYE, REFER, SUBSCRIBE, NOTIFY
Supported: replaces, timer, 100rel, in-band-dtmf
Reason: Q.850;cause=21
Reason protocols: Q.850
Cause: Call rejected (21)
Content-Length: 0
Sinhro
Re: Проблема сетевого вызова по SIP протоколу
Сообщение Sinhro »
Скрины настроек SIP W&T-NS100
Благодарил (а): 283 раза
Дамп проблемного вызова снимите с W&T и сюда. Как снять дамп
Можете подписаться на канал wink3
Sinhro
Сообщение Sinhro »
INVITE sip:600@192.168.46.20:30565 SIP/2.0
From: <sip:190@192.168.46.20:5060>;tag=61776e18-f91fa8c0-13dd-65014-36f264-190bb99d-36f264
Call-ID: 6190eff8-f91fa8c0-13dd-65014-36f264-57a80307-36f264
CSeq: 1 INVITE
Via: SIP/2.0/UDP 192.168.40.245:5060;rport;branch=z9hG4bK-36f264-d6a2da4d-6ac04462-615daeb8
Max-Forwards: 70
Allow: INVITE,ACK,OPTIONS,BYE,CANCEL,REGISTER,REFER,SUBSCRIBE,NOTIFY,MESSAGE,INFO,PRACK,UPDATE
Supported: replaces,UPDATE,INFO
User-Agent: Ericsson-LG Enterprise iPECS-eMG eMG800 4.0.9
Contact: <sip:190@192.168.40.245:5060;transport=UDP>
Content-Type: application/sdp
Content-Length: 248
v=0
o=iPECS-eMG 28 28 IN IP4 192.168.40.245
s=iPECS-eMG SIP
c=IN IP4 192.168.40.245
t=0 0
m=audio 7114 RTP/AVP 0 8 18 4
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:4 G723/8000
a=sendrecv
CSeq: 1 INVITE
Max-Forwards: 70
Content-Length: 248
v=0
s=iPECS-eMG SIP
t=0 0
a=fmtp:18 annexb=no
a=sendrecv
Via: SIP/2.0/UDP 192.168.40.245:5060;branch=z9hG4bK-36f264-d6a2da4d-6ac04462-615daeb8;received=192.168.40.245;rport=37013
To: <sip:600@192.168.46.20:30565>;tag=as5365c051
CSeq: 1 INVITE
Server: W&T
Content-Length: 0
CSeq: 1 INVITE
Server: W&T
Content-Length: 0
ACK sip:600@192.168.46.20:30565 SIP/2.0
CSeq: 1 ACK
Max-Forwards: 70
Content-Length: 0
CSeq: 1 ACK
Max-Forwards: 70
Content-Length: 0
У вас порт указан 5060. А инвайт приходит на 30565. Вот станция и ругается
Sinhro
Сообщение Sinhro »
vda писал(а): 01 дек 2025, 07:00 У вас порт указан 5060. А инвайт приходит на 30565. Вот станция и ругается
5060 это udp станции LG.
30565 это udp w&S-ns
У тебя на скриншоте указан 5060
Sinhro
Сообщение Sinhro »
vda писал(а): 01 дек 2025, 10:08 У тебя на скриншоте указан 5060
Здесь же указывается udp порт стации LG.
на трассе форбиден. Это может быть несколько разных причин для доверительного транка
1. Несовпадение по портам
2. Инвайт приходит не с того адреса, что назначен
3. Станция забанила этот айпи адрес по каким-то причинам (слишком часто долбится, например)
Я бы начал с портов. сделай их одинаковыми и посмотри
Sinhro
Сообщение Sinhro »
Сделал порты udp на обеих станциях одинаковыми. Проблема осталась.
