[phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 279: mysqli_fetch_assoc(): Couldn't fetch mysqli_result [phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 343: mysqli_free_result(): Couldn't fetch mysqli_result [phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 279: mysqli_fetch_assoc(): Couldn't fetch mysqli_result [phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 343: mysqli_free_result(): Couldn't fetch mysqli_result [phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 279: mysqli_fetch_assoc(): Couldn't fetch mysqli_result [phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 343: mysqli_free_result(): Couldn't fetch mysqli_result [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4191: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3076) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4191: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3076) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4191: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3076) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4191: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3076) [phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 279: mysqli_fetch_assoc(): Couldn't fetch mysqli_result [phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 343: mysqli_free_result(): Couldn't fetch mysqli_result V-IPEXT32 - Страница 2 - Форум мини АТС компании Солярис
toka писал(а): ↑01 июн 2023, 05:39
Я же правильно понимаю, что 8 встроенных лицензий для системных IP-телефонов на DSP16 должны позволять подключить 8 IP-телефонов через V-IPEXT32?
Это в том случае, если ключи видно в окне "Ключи Активации".
Не всегда, если установлен DSP, есть ключи на IP телефоны и/или транки.
Шаманство сплошное.
Даунгрейд с 8.0102 на 7.1008 исправил ситуацию.
Все стало сохранятся без ошибок и IP-аппарат зарегился.
Вопрос:
1. что не так с прошивкой 8.0102?
2. не подкинет ли кто мне еще какой либо релиз 8-й версии для теста?
toka писал(а): ↑01 июн 2023, 17:00
Шаманство сплошное.
Вопрос:
Неправильно был конвертирован конфиг 7-й версии в 8-ю, как вариант.
Может ещё, что коряво было сделано.
