[phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 279: mysqli_fetch_assoc(): Couldn't fetch mysqli_result [phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 343: mysqli_free_result(): Couldn't fetch mysqli_result [phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 279: mysqli_fetch_assoc(): Couldn't fetch mysqli_result [phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 343: mysqli_free_result(): Couldn't fetch mysqli_result [phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 279: mysqli_fetch_assoc(): Couldn't fetch mysqli_result [phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 343: mysqli_free_result(): Couldn't fetch mysqli_result [phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 279: mysqli_fetch_assoc(): Couldn't fetch mysqli_result [phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 343: mysqli_free_result(): Couldn't fetch mysqli_result [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4191: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3076) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4191: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3076) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4191: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3076) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4191: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3076) [phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 279: mysqli_fetch_assoc(): Couldn't fetch mysqli_result [phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 343: mysqli_free_result(): Couldn't fetch mysqli_result V-IPEXT32 - Страница 3 - Форум мини АТС компании Солярис
toka писал(а): ↑01 июн 2023, 17:00
Шаманство сплошное.
Даунгрейд с 8.0102 на 7.1008 исправил ситуацию.
Все стало сохранятся без ошибок и IP-аппарат зарегился.
Вопрос:
1. что не так с прошивкой 8.0102?
2. не подкинет ли кто мне еще какой либо релиз 8-й версии для теста?
Никакого шаманства, делал благополучно такие операции черт знает сколько раз... С прошивкой всё так, проверена временем. Полагаю, что-то не так с Вашими руками и (или) Вашим железом.
Mike_K писал(а): ↑02 июн 2023, 06:41
Неправильно был конвертирован конфиг 7-й версии в 8-ю, как вариант.
Может ещё, что коряво было сделано.
Конфига нет априори (если читать внимательно). Перепрошито и настраивалось с нуля. Сейчас те же настройки сделанные в ручную только на 7-ке и все без проблем.
toka писал(а): ↑02 июн 2023, 08:57
Тогда интересно услышать как на АТС ставилась 8я версия.
Mike_K писал(а): ↑02 июн 2023, 12:49
И всё? Тогда понятно.
Ну если этого недостаточно, тогда скажите, что еще лить?
P.S. Естесно не описываю все действия, что предлагала АТС-ка после заливки (Типа заменить на новую и перезагруз).
Mike_K писал(а): ↑02 июн 2023, 09:46
Ну и после того как переключатель поставили в SYSTEM INITIALIZE,
АТС ресетили кнопкой на процессоре или выключателем питания на БП?
Не бесследно проходит отсутствие общения с АТС с перерывом почти в 10-ток лет.
Косяк понятен. Тема закрыта.
