[phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 279: mysqli_fetch_assoc(): Couldn't fetch mysqli_result [phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 343: mysqli_free_result(): Couldn't fetch mysqli_result [phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 279: mysqli_fetch_assoc(): Couldn't fetch mysqli_result [phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 343: mysqli_free_result(): Couldn't fetch mysqli_result [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4191: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3076) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4191: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3076) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4191: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3076) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4191: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3076) [phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 279: mysqli_fetch_assoc(): Couldn't fetch mysqli_result [phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 343: mysqli_free_result(): Couldn't fetch mysqli_result Порт MNT - Форум мини АТС компании Солярис
Здравствуйте. Прошу проконсультировать. Можно ли порт MNT кинуть через коммутатор и снимать с него трассу удалённо? Или же только посредством прямого подключения?
roklista писал(а): ↑10 янв 2024, 05:22
Правильную трассу можно снять прямым подключением к порту MNT,
но порт MNT ещё дополнительно программировать придётся.
По умолчанию этот порт не для снятия трассировки.
А как Вы с коммутатора удаленно снимать трассу хотите?
Начальство придумало вести запись трассы в реальном времени прямо на сервер. Хочет удалённо, через коммутаторы, чтобы не тянуть провод. Вот и хочет узнать, возможно ли это или нет.
Так и скажи, что это возможно, но значительно дороже чем тянуть провод )))
roklista писал(а): ↑11 янв 2024, 07:24
Хотим постоянно трассу удалённо снимать прямо на сервер, а не на комп. Я так понял, что реально, но заморочь будет.
Что хотите получить от трассировки из АТС?
Просто, очень странное желание.
